I have 4 SFP Cisco MA-SFP-1GB-TX, I am connecting to an MX250 but the Internet port of the MX does not turn on as a result the device does not connect to the cloud.
I have tested these SFPs in the two internet ports in two different MXs but in each of the ports it is the same does not turn on.
I ran into something similar with 1gig SFP's on the WAN port of an MX250 or 450, forget which. After a firmware upgrade the SFP worked fine. What version is yours?
I will warn you - I had this happen with a Proline SFP. Seemed to work for awhile after a firmware upgrade, then died again without warning a couple of months later. I've replaced all the suspect SFPs in our MX250s, no issues since.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_654d2f116ae7bd","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_654d2f116ae7bd_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_654d2f116ae7bd_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_654d2f116ae7bd_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_654d2ef51beebc","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
