Port Schedule Custom?
NolanHerring
Hey guys,
Looking for a way to disable a port and re-enable it after a minute or two, on weekly basis, to reboot an access point.
I was hoping to find a way to do this via port scheduling but it looks like they only allow 30 minute intervals at the smallest time frame.  I don't want the AP down for 30 minutes, just need to reboot it automatically and this was the only clever way I could come up with.
Any ideas?
Nolan Herring | nolanwifi.com
TwitterLinkedIn
BrechtSchamp
Disable and enable the switchport via api and link the script to cron job?
{{baseUrl}}/devices/{{serial}}/switchPorts/{{portNum}}
BrechtSchamp
+1 to using the API.
Second option; buy an extra AP for the area so they have substantially overlapping coverage, and turn one off for 30 minutes and then the other at a different time.
Third option; power the AP using a PoE injector or power cube, and get a manual on/off timer power point.
NolanHerring
Good idea !
I'll look into doing that. thanks for the idea
TwitterLinkedIn
