Port Profiles
303nir
Port Profiles
When I go to edit a switchport I do not see the port profile option.
FYI, the switch is a 9300.
KH
Meraki Employee All-Star
Hey @303nir
It doesn't look like C9300s are supported with Port Profiles/SmartPort. You will likely have to put in a feature request by reaching out to your account team or clicking the give your feedback button on the dashboard.
"SmartPorts are supported on the MS120, MS125, MS130, MS130R, MS210, MS225, MS250, MS350, MS355, MS410, MS425 and MS450 series switches"
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/SmartPorts#Requirements.2C_guideline...
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
1 Reply 1
KH
Hey @303nir
