Hi Community
I was wondering if anyone has managed to get Multicast routing working on Meraki MS?
I seem to run into walls the whole time and I have an IPTV Vendor installing a system and ATM it seems that it is the Meraki keeping them back.
So we have a headend appliance on an HP switch that the AV manages and supplies. They do PIM-SM and connect to the Meraki using vlan 1201. When they put a client on vlan 1201 on their switch the multicast works exactly as it should. So we connect vlan 1201 to Meraki and the PIM-SM relationship forms no issues. Then I retreive a stream lets say 239.1.2.1 and it works no issues. But as soon as I start a second stream the issues start, then nothing works. Have to start resetting the Meraki PIM settings to get it back up.
So further to this I thought, ok let me put a laptop of my own in vlan 1201 as well. So in this case we have headend behind HP switch in VLAN 120 with PIM. AV Laptop on HP switch in vlan 1201 and my laptop in vlan 1201 on Meraki.
Surely enough, the AV Laptop connected to the HP switch receives the stream no issue. My laptop on the Meraki does not but I am in the same VLAN now as the AV Laptop on the HP switch. So I started with disabling IGMP and then PIM all together. To have just a standard VLAN, still cant retrieve the streams.
So I said, lets move the headend onto the Meraki to get rid of HP/Meraki interoperabilities. So now we have the headend spitting out Multicasts on the Meraki switch in VLAN 120, my client laptop on the same vlan also. Now I open the multicast but there is no content which is odd as I am now in the same VLAN. The same test done on the HP switch works perfectly fine.
So now I enable PIM again for that VLAN and an access vlan 63.
Now I have headend still on vlan 120 with PIM and laptop on same switch vlan 63.
IP Address Subnet Flags Neighbors
10.0.1.110 10.0.1.96/28 DR PIM
1 neighbor
Source Group Rendezvous Point Incoming Interface Outgoing Interfaces Flags
Any 239.1.2.1 10.0.1.110 PIM Register
1 interface
WC RP
192.168.120.2 239.1.2.1 10.0.1.110 192.168.120.1
1 interface
CACHE SG
192.168.120.2 239.1.2.2 10.0.1.110 192.168.120.1
CACHE SG
192.168.120.2 239.1.2.3 10.0.1.110 192.168.120.1
CACHE SG
So now, I do the same test and it seems the stream opens I can see on a sniff also surely I am receiving the multicast streams but it simply does not have any content.
I am so confused/frustrated by this.
Hence the question, has anyone been able to successfully implement this yet?
