Switch firmware versions MS 15.9 changelog
Alerts
- HTTP proxy is no longer supported on MS 15+. Nodes that use HTTP proxy without any other means to connect to dashboard may fail to connect.
- MS390 ports are not disabled when configured to do so in dashboard (present since MS 15.1)
- Moving or re-provisioning an MS390 stack in dashboard can cause the management plane of at least one member to stay offline until rebooted (present since MS 15.0)
- MS390 upgrades from MS 15.8 or later will result in minimal impact to client traffic
Branch additions
- STP anomaly detection support for MS390 series switches
- IPv6 static routing support for MS390 series switches
- Additional client analytics added for MS390 series switches
- Meraki authentication support for MS390 series switches
- Alternate Management Interface (AMI) support for MS390 series switches
- UDLD support for MS390 series switches
- Group policy ACL support for MS390 series switches
- IPv6 management interface support
- URL redirect support for MS390 series switches
- UPoE (802.3bt) support for MS390 series switches
- Critical/failed authentication support for MS390 series switches
- Multi-auth with voice VLAN bypass support
- MAC flap detection support for MS390 series switches
- Named VLAN support for MS120/125/210/225/250/350/355/390 series switches
- Stack power is supported by default for MS390 series switches
- Netflow and Encrypted Traffic Analytics (ETA) support for MS390s
Bug fixes
- MS120/125 series switches with a storm control configuration do not correctly police traffic (always present)
- When dashboard authentication services for SecureConnect are unreachable, ports may report the incorrect status
- MRs may fail to authenticate via SecureConnect if dashboard connectivity is not established at the time of the authentication request
- MS390 platform switches send excessive client deauthentication event log messages
- SecureConnect fails on MS355 platform switches (present since MS 15.1)
- Custom IPv6 DNS servers would not be correctly applied
- Stack members may go offline and require a reboot to regain connectivity (present since MS 12)
Known issues
- Port isolation fails to isolate traffic between ports (present since MS 15.9)
- Stack ports may fail to initialize properly upon reboot. A subsequent reboot of the switch would be needed (present since MS 14)
- If the voice VLAN authenticates before the data VLAN, the voice VLAN will stop working after the data VLAN authenticates (present since MS 14.28)
- When applying an access policy to a port, voice VLAN clients will not be updated in the MAC table without bouncing the port (present since MS 14.28)
- MA-SFP-1GB-TX links may fail to reconnect after link loss (present since MS 12)
- Connecting a stacking cable to a stack that is online may result in a stack member going offline (present since MS 12)
- Networks containing a large number of switches may encounter issues saving changes on the Switch Settings page
- Stack members may experience delays in updating their configuration for up to an hour after a config change (present since MS 9)
- Cable tests run on 100Mbps connections may return the wrong information (predates MS 9)
- The "clone from" list may fail to load when cloning a switch in an organization with 1,000+ switches or networks
- Changes made to SVIs may result in connectivity loss for one or more SVIs until reboot (present since MS 14.31)
- Broadcast types of traffic can leak into the Guest VLAN if a port that fails authentication has a voice VLAN configured, and dashboard has a Guest VLAN defined (present since MS 11)
- AMI IP addresses do not send gratuitous ARP packets which can lead to packet loss if the AMI address has aged out in the network
- Meraki authentication does not work with guest VLAN
MS12x
- Ports with an odd-numbered MTU value fail to initialize for MS120/125 series switches (predates MS 11)
- In rare instances, MS120 series switches may have empty packet captures until they are rebooted
- Links being established on an MS120 can result in neighboring ports to flap (present since MS 11)
- MS120 series switches in extremely rare instances will experience reboots every few minutes (present since MS 11)
- MS120s switch ports with MAB authentication may randomly deauthenticate clients. In order to resume client authentication on that port, a switch reboot is required (present since MS 12)
MS2xx
- In rare instances MAC addresses will fail to be relearned on ports configured with Access Policies. This is currently scoped to only impact MS210/250 models (present since MS 12)
MS3/4xx
- MS350-24X and MS355 series switches do not negotiate UPoE over LLDP correctly (predates MS 10)
- MS350/450 series switches in a stack configuration will lose dashboard connectivity if a "Deny Any Any" ACL is added without having higher "Allow" rules in place for dashboard connectivity (predates MS 12)
- Enabling Combined Power on MS350/355 switches results in events being logged once per minute (present since MS 11)
- mGig switches will have an amber light for all physical ports that do not negotiate to the highest supported speed. Dashboard will continue showing a light green status for all ports above 100Mbps. For example, MS355 switch ports will incorrectly show an amber light for 1G, 2.5G, and 5G, but will show a green light for 10G.
- When an SFP module is inserted/removed on MS420/425 series switches, BPDUs can be delayed leading to STP transitions in the network (predates MS 12)
MS390
- MS390 stack members may experience a full system restart
- When the MS390 management plane experiences a restart, LACP flapping can occur
- MS390 stacks may send frequent DHCP requests despite having a valid static IP address, which can result in IP flapping (present since MS 14)
- In rare circumstances, MS390 series switches may disconnect from dashboard until rebooted. Data plane traffic is not impacted unless RADIUS authentication is used (present since MS 14.28)
- Packet loss is observed when pinging the MS390 management IP (present since MS 12)
- MS390 "Port Up/Down" events will be shown across all members
- MS390 series switches do not support loop detection
- MS390 series switches do not support warm spare/VRRP
- Rebooting an MS390 switch in a stack via the UI will result in the entire stack rebooting
