New MS 15.3 beta firmware - SFP modules now work
Switch firmware versions MS 15.3 changelog
Alerts
  • HTTP proxy is no longer supported on MS 15+. Nodes that use HTTP proxy without any other means to connect to dashboard may fail to connect.
  • MS210/225/250/350/355/410/425 series switches may be unable to initialize 1Gbps SFP modules. This is currently scoped to only impact some MA-SFP-1GB-SX modules (present since MS 15.0).
  • SecureConnect fails on MS355 series switches
  • MS390 ports are not disabled when configured to do so by dashboard
  • Moving or re-provisioning an MS390 stack in dashboard can cause at least one member to stay offline until rebooted (this only affects control plane traffic).
  • MS390 upgrades from MS 15.2 or later will result in minimal impact to client traffic
Branch additions
  • IPv6 static routing support for MS390 series switches
  • Additional client analytics added for MS390 series switches
  • Meraki authentication support for MS390 series switches
  • Alternate Management Interface (AMI) support for MS390 series switches
  • UDLD support for MS390 series switches
  • Group policy ACL support for MS390 series switches
  • IPv6 management interface support
  • URL redirect support for MS390 series switches
  • UPoE (802.3bt) support for MS390 series switches
  • Netflow export for Adaptive Policy
  • Critical/failed authentication support for MS390 series switches
  • Multi-auth with voice VLAN bypass support
  • MAC flap detection support for MS390 series switches
  • Named VLAN support for MS120/125/210/225/250/350/355/390 series switches
  • Stack power is supported by default for MS390 series switches
  • Netflow support for MS390 series switches
Bug fixes
  • SFP modules plugged into SFP+ ports will not initialize for the MS210/225/250/410 series switches
  • Stability improvements for the MS390 series switches
  • ACL configurations are not removed for MS390s when updated to do so. A reboot resolved this (present since MS 14.26)
Known issues
  • Group-policy ACL rules that use TCP or UDP port ranges apply for a single port in the range on MS390 series switches
  • In rare scenarios, changes made to SVIs may result in connectivity loss for one or more SVIs until reboot (predates MS 12)
  • In rare instances, DAI inspection may fail to snoop DHCP transactions on stacks leading to those clients being in a blocked state
  • MS390 ports are limited to the lowest link speed since boot if QoS is enabled
  • Connecting a stacking cable to a stack that is online may result in a stack member going offline (present since MS 12)
  • In rare instances, MS120 series switches may have empty packet captures until they are rebooted
  • In rare instances, a stack member may go offline until rebooted (present since MS 12)
  • MS390s may experience a brief 1-2 minute control plane outage. The data plane will not experience issues during this time.
  • Packet loss is observed when pinging the MS390 management IP
  • Links being established on an MS120 can result in neighboring ports to flap (present since MS 11)
  • MS390 - Port Up/Down Events Shown Across All Members
  • Enabling Combined Power on MS350/355 switches results in events being logged once per minute (present since MS 11)
  • Networks containing a large number of switches may encounter issues saving changes on the Switch Settings page
  • Stack members are not being marked to update their configuration when changes are made on other members
  • mGig switches will have an amber light for all physical ports that do not negotiate to the highest supported speed. Dashboard will continue showing a light green status for all ports above 100Mbps. For example, MS355 switch ports will incorrectly show an amber light for 1G, 2.5G, and 5G, but will show a green light for 10G.
  • The list of switches to clone from fails to load when cloning a switch in an organization with a large number of switches and networks
  • Broadcast types of traffic can leak into the Guest VLAN if a port that fails authentication has a Voice VLAN configured, and dashboard has a Guest VLAN defined (present since MS 11)
  • MS120s switch ports with MAB authentication may randomly deauthenticate clients. In order to resume client authentication on that port, a switch reboot is required (present since MS 12)
  • MS390 series switches do not support MAC whitelists
  • MS390 series switches do not support loop detection
  • MS390 series switches do not support warm spare/VRRP
  • MS350-24X and MS355 series switches do not negotiate UPoE over LLDP correctly (predates MS 10)
  • Rebooting any MS390 stack member via the UI will result in the entire stack rebooting
  • AMI IP addresses do not send gratuitous ARP packets which can lead to packet loss if the AMI address has aged out in the network
  • Meraki authentication does not work with guest VLAN
  • Ports with an odd-numbered MTU value fail to initialize for MS120/125 series switches (predates MS 11)
  • When an SFP module is inserted/removed on MS420/425 series switches, BPDUs can be delayed leading to STP transitions in the network (predates MS 12)
0 Replies 0
