New MS 15.14.2 beta firmware: STP crash and dashboard connectivity fix
Switch firmware versions MS 15.14.2 changelog
Alerts
  • HTTP proxy is no longer supported on MS 15+. Nodes that use HTTP proxy without any other means to connect to dashboard may fail to connect.
  • MS390 upgrades from MS 15.14 or later will result in minimal impact to client traffic
  • MS390 series switches can only downgrade to MS 12 with an incremental step to MS 14
Branch additions
  • STP anomaly detection support for MS390 series switches
  • IPv6 static routing support for MS390 series switches
  • Additional client analytics added for MS390 series switches
  • Meraki authentication support for MS390 series switches
  • Alternate Management Interface (AMI) support for MS390 series switches
  • UDLD support for MS390 series switches
  • Group policy ACL support for MS390 series switches
  • IPv6 management interface support
  • URL redirect support for MS390 series switches
  • UPoE (802.3bt) support for MS390 series switches
  • Critical/failed authentication support for MS390 series switches
  • Multi-auth with voice VLAN bypass support
  • MAC flap detection support for MS390 series switches
  • Named VLAN support for MS120/125/210/225/250/350/355 series switches
  • Stack power is supported by default for MS390 series switches
  • Netflow and Encrypted Traffic Analytics (ETA) support for MS390s
Bug fixes
  • Stacks in rare circumstances will crash if STP TCNs are seen at the same time as it is snooping DHCP traffic
  • MS120/125/355/390/450 management connectivity to dashboard can intermittently fail resulting in brief disconnects (present since MS 15.1)
Known issues
  • MS390 management plane may encounter infrequent restarts (always present)
  • MS390 series switches in rare instances disconnect from dashboard until rebooted (present since MS 14.33)
  • MS390s in rare circumstances will experience a full system restart (preset since MS 14)
  • When the MS390 management plane experiences a restart, LACP flapping can occur
  • Stack ports may fail to initialize properly upon reboot. A subsequent reboot of the switch would be needed (present since MS 14)
  • MS390s that receive incorrectly flooded CDP packets may incorrectly report VLAN mismatches and SFP port information (present since MS 12)
  • Connecting a stacking cable to a stack that is online may result in a stack member going offline (present since MS 12)
  • In rare instances, MS120 series switches may have empty packet captures until they are rebooted
  • Switch stacks will learn MAC addresses from ports in the STP blocking state which can trigger a constant flood of MAC flaps in the event log
  • Links being established on an MS120 can result in neighboring ports to flap (present since MS 11)
  • MS120 series switches in extremely rare instances will experience reboots every few minutes (present since MS 11)
  • MS390 "Port Up/Down" events will be shown across all members
  • IGMP querier is enabled on all VLANs resulting in IGMP messages being sent every 125 seconds. Layer 2 switches use the management IP as the querier address. (always present)
  • Enabling Combined Power on MS350/355 switches results in events being logged once per minute (present since MS 11)
  • Networks containing a large number of switches may encounter issues saving changes on the Switch Settings page
  • Stack members may experience delays in updating their configuration for up to an hour after a config change (present since MS 9)
  • mGig switches will have an amber light for all physical ports that do not negotiate to the highest supported speed. Dashboard will continue showing a light green status for all ports above 100Mbps. For example, MS355 switch ports will incorrectly show an amber light for 1G, 2.5G, and 5G, but will show a green light for 10G.
  • LACP bundles configured across stack members experience brief outages when a stack member goes offline and again when it comes online (present since MS 10)
  • MS390 stacks may send frequent DHCP requests despite having a valid static IP address, which can result in IP flapping (present since MS 14)
  • LACP bundles spanning multiple stack members can result in a temporary loop if one of the stack members is rebooted (present since MS 11)
  • In rare instances, RADIUS accounting sessions may not be removed after a client disconnects with an EAPoL logoff message (present since MS 11)
  • Broadcast types of traffic can leak into the Guest VLAN if a port that fails authentication has a voice VLAN configured, and dashboard has a Guest VLAN defined (present since MS 11)
  • MS390 series switches do not support loop detection
  • MS390 series switches do not support warm spare/VRRP
  • MS350-24X and MS355 series switches do not negotiate UPoE over LLDP correctly (predates MS 10)
  • AMI IP addresses do not send gratuitous ARP packets which can lead to packet loss if the AMI address has aged out in the network
  • Meraki authentication does not work with guest VLAN
  • Moving or re-provisioning an MS390 stack in dashboard can cause the management plane of at least one member to stay offline until rebooted (present since MS 15.0)
  • Ports with an odd-numbered MTU value fail to initialize for MS120/125 series switches (predates MS 11)
  • When an SFP module is inserted/removed on MS420/425 series switches, BPDUs can be delayed leading to STP transitions in the network (predates MS 12)
  • MS350/450 series switches in a stack configuration will lose dashboard connectivity if a "Deny Any Any" ACL is added without having higher "Allow" rules in place for dashboard connectivity (predates MS 12)
  • Rebooting an MS390 switch in a stack via the UI will result in the entire stack rebooting
I'd like to see:
ALERTS
  • MS390 works
rhbirkelund
Hah! 😄
ChinWai
Has anyone upgraded to 15.14.2 on MS390 and is it stable?
_DanieL_
we updated some branches and RADIUS doesn't work anymore. Case is opened.
Anyone else with the same Problem or can confirm?
Running 15.14.2 right now.
Edit: Mainly using MS120, MS225 and MS210.
