Multiple Layer 3 switch routing
L4d1k
I am trying to utilize our Layer 3 switches for VLAN routing.
Can I get some assistance with this configuration:
VLAN 1 Default (transport)
 192.168.2.0/22
VLAN 10 VoIP
 192.168.2.0/24
VLAN 20 Staff
192.168.3.0/22
VLAN 30 Guest
192.168.4.0/22
Local DHCP (not Meraki)
192.168.2.30
Local DNS
192.168.2.30
Firewall MX250
MS350 L3 switches 5x
MS220 L2 Switches 5x
Not sure in which order or if I am missing anything but it looks like it takes 3 different places to set it up:
1. under switches/ configure/ DHCP & routing
  Interfaces
2. under switches/ configure/ DHCP & routing
  Static routes
3. Security & SD-Wan/ configure/ Addressing & VLANs
  Static Routes
Thank you!
5 Replies 5
KarstenI
You are right.
1: All your VLANs that you want to route internally.
2: typically a default route is fine here.
3: Routes to all VLANs that you configured in Step 1. But also all VLANs that you need to segment for security. For example your DMZs. Depending on the environment, I have all my VLANs here and not on the L3-switch.
L4d1k
Yes that is the document I was using.
I just wish there was one with more details and included more pictures or videos with the Meraki interface and what was configured.
Ideally with multiple L3 switches and multiple VLANs
You need non overlapping subnets:
 192.168.2.0/22 - this includes IP addresses 192.168.0.1 to 192.168.3.254
VLAN 10 VoIP
 192.168.2.0/24 - overlaps with the above /22
VLAN 20 Staff
192.168.3.0/22 - this is the same as the first subnet
VLAN 30 Guest
192.168.4.0/22 - this is also the same.
You need unique subnets.
L4d1k
Yes, the subnets are unique.
I didn't put the subnets in use I only used it as an example and didn't do the right subnet mask.
For test purposes/24 on all subnets should be ok.
