Multicasting
JThorne
Multicasting
By initiating multicasting on a MS will it reboot the switch or affect the switch performance or users in any way?
Nope.
Nope.
JThorne
Thanks for your response.
Heavy flows can affect switch performance.  For example, if you have a 1Gb/s multicast flow coming into a port on a 48-port switch where the other 47 ports are a member - it would have to duplicate that packet 47 times - producing 47 Gb/s of bandwidth.
Back in Cisco Enterprise land, I have had this problem with companies that use lots of multicast (usually for media) and I have had to put in higher-end switches to cope with those flows.
If your flows are small, you have nothing to worry about.
