Moving switch to different network
I have a new site with a MX appliance in it. A MS series switch is connected to the MX.
I also have a central site, and when we added a new switch license/inventory, the switch shows up in the central site. If I go to monitor-switches and click "edit" and move, I don't have the option to move the switch to the other location. The second location doesn't show up.
How do I do this?
2 REPLIES 2
Re: Moving switch to different network
If you select the switch in the list of switches and remove it from your central network you'll be able to put it in a new network from the inventory.
Go to the inventory, select it, and use the "Add to..." button to add it to a new network.
that worked, thanks!
