Migrating c4500x and c2960 to Meraki MS410 , MS250
patkm
Just browsing
Anyone has a good documentations/ guidance to transfer  config  across manually or automatically. from c4500x and c2960 to Meraki MS410 , MS250.
How to config VLANs, portchannel, ACL, Qos, ospf, static routes etc. Thanks
There is no documenttion to migrate a catalyst switch for a MS switch, but you can find everything what you want here.
https://documentation.meraki.com/MS
patkm
Just browsing
Thanks for your reply, that is helpful
In the Meraki github there are several migration scripts to assist.
https://github.com/meraki/automation-scripts
There is no direct migration for a 4500 - as they have lots of slots, and an MS switch is effectively "one slot" - but you could modify the "migrate_cat3k" script to copy the different blades to different switches.
