Meraki switch cannot go online on cloud
KevinJume
Hi all,
Previously, we onboarded our Meraki switches on the cloud for POC. After the POC, we switch off the switches.
Months later, we switched back on, but the Meraki switch is not showing online on the Meraki cloud anymore.
We verified we have sufficient licenses and the switches can get DHCP and have access to the internet.
Does anyone have any idea? What should I do next?
5 Replies 5
Try restoring the switches to their factory settings.
KevinJume
HI @alemabrahao ,
Do I physically press and hold onto the reset pinhole for 10seconds?
https://documentation.meraki.com/Platform_Management/Dashboard_Administration/Troubleshooting_and_Su...
If you connect to the local status page, what does it say the problem is?
IvanJukic
Meraki Employee All-Star
Hi @KevinJume,
"We verified... the switches can get DHCP and have access to the internet."
After the factory reset as suggested by @alemabrahao and checking the Local Staus Page as per @PhilipDAth .
- Make sure the switch's management VLAN is configured correctly, or left blank if it should be untagged.
- Make sure there are no firewalls that could be blocking the switch's management traffic.
https://documentation.meraki.com/Switching/MS_-_Switches/Troubleshooting_and_Support/Troubleshooting...
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
