Meraki lack of Support with Server 2022 SET vswitches
Gumberculeez
Hey Guys;
I'm currently dealing with a windows server 2022 issue post update (KB5025230).  It seems this update as updated the SET protocol and the meraki switch now labels an error on those ports.
the internet responses I'm seeing is Meraki doesn't actually support SET teaming.  Which is an issue as server 2022 doesn't do LBS vswitches anymore... only SET.
My MS220 is currently running MS 14.33 firmware.  Is this going to be corrected in a future release?
2 Replies 2
Maybe it will help you.
https://community.spiceworks.com/topic/2358178-windows-server-2022-hyper-v-switch-embedded-teaming-w...
GreenMan
Meraki Alumni (Retired)
I very much doubt this will be supported on that switch platform in the future - t's both End of Sale and was designed as an edge access switch (think:  aimed at PCs, printers, WiFi APs etc).   LACP teaming only for that switch range, I would suggest:  https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Link_Aggregation_a...
Bear in mind too, in reference to @alemabrahao 's link:   the MS220 doesn't support physical stacking either:   ports in a Link Aggregation Group all need to go to the same switch
