Meraki equivalent to Catalyst 9500 (C9500-48Y4C-E)
Dolik
Hi, I am looking for equivalent of Catalyst core switch 9500, SKU C9500-48Y4C-E. Same would be for Catalyst Access Point 9130.
Martin
3 REPLIES 3
@Dolik there aren't model for model equivalents, what features of the devices are you looking to use?
The nearest Meraki model to the 9130 is the MR56 as it has 8 spatial streams and is Wi-Fi6 enabled, but it doesn't support external antennas, 160MHz channels or splitting the radios.
The nearest MS devices to the 9500 are the MS4xx switches but they do not support SFP28
