Meraki MS425 Switches supports ?
Keval
One of my client has HP servers and he want to use our Meraki SFP for connectivity .
HP team has share below features which should be support with meraki switch .
Proposed Switch - MS425-32-HW,
Requirements .
1. Switch must meet the following requirments.
     a. Supports IPV4 Unicast.
     b. support IPV6 Multicast.
     c. supports IPV4 Multicast.
     d. Enable IGMP snoophing and querier.
     e. Enable MLD snooping and querier.
kindly help us to conforming me above features will support or not ?
keval parsaniya
4 REPLIES 4
Inderdeep
Yes it is supported @Keval
https://meraki.cisco.com/product-collateral/ms425-series-datasheet/?file
Regards/Inder
www.thenetworkdna.com
What are the buffer specs on the MS425??  I cannot find that info on the datasheet.  Does anyone have that info??
Buffer specifications are not published.  You can get this info by reaching out to a Meraki rep.
BlakeRichardson
@Keval  Meraki offers trial equipment which might be a good idea, you can order the hardware you want on a trial and if your happy with it purchase that hardware, if not return it.
