Meraki MS225 Stacking issue
Paul_B
We recently purchased 5 Meraki MS225 switches to be setup in two stacks.  Per documentation, we connected an uplink to all switches and let them load the latest firmware.  Powered them down, stacked them in a ring configuration, and than powered back up.  However none of the switches are showing the stack ports as active, and only the switch in the stack with the uplink port is showing connected.
I have tried manually configuring the stacks correctly, but that didn't fix it.  Any suggestions, and why the stack ports are not showing active even through we have them properly physically stacked and powered up.
thanks,
Paul
1 Reply 1
The switches sometimes take up to 45 minutes to complete their upgrades.  I usually plug them in one day and do the actual job the next day.
