Meraki MS connect to Cloud
SopheakMang
Dear Expert ,
i am kinda new to meraki MS , i now can connect MS to cloud and manage some features ,
but i see management uplink connect ms to cloud has only one link. is there any way that i can bind port 2-3 ports for redundancy when link fail ?  so i can keep my MS connect to cloud without worry on one single link failure.
pls advise
1 Reply 1
jdsilva
MS switches will try to reach the cloud on any and every ports, using any and every VLAN they can find to reach the cloud. You don't need to configure this, it'll just happen.
