MS410 and MS425 Stack
Adoos
This is possibly a silly question but can you stack the  MS410 and MS425?
No. The MS410 uses physical stacking while the MS425 uses a different method, flexible stacking.
There is some info here:
https://documentation.meraki.com/MS/Stacking/Switch_Stacks
2 Replies 2
Adoos
 Yep, just read that.
Only like-models can be stacked. For example, MS350-48 and MS350-24X can be stacked, but MS250-48 cannot be stacked with a MS350-48. The MS210 and MS225 series are also cross-compatible with physical stacking.
Thanks!
