Hello!
I've been doing some more testing and thinking about this and I've run into a design consideration issue.
I've concluded (unless I'm mistaken) that it's not possible to reach the IP address the MS390 use for communication with the cloud via the route which I distribute through OSPF. It is possible to reach the IP address of the interface I've setup as an additional interface on the MS390 which is part of the same subnet as the IP used for cloud communications which is setup so that I may redistribute the subnet throughout the OSPF domain. Is this behavior specific to MS390?
EDIT: Since MS390 isolates the control traffic from the data traffic it is not possible to reach the mgmt IP via the OSPF route (even if the SVI created in the MS390 to enable the route to be propageted throught OSPF lies within the same subnet), you're essentially creating a dual-purpose subnet/VLAN with some form of segmentaion invisible to the user, it would make more sense not to allow it at all I think. This also creates a little bit of a problem regarding management since you have to resort to static routing for the mgmt features to work as expected. I can see the benefit regarding security, but it should be an option to let the designer of the network take proper measures to secure the mgmt plane themselves.
Imagine we'd like to use the subnet which is used for cloud communications for some internal service, for example SNMP. This means that we have to setup an additional IP address for every MS390 used as a L3 device on the subnet which means that we have to use 2x IP addresses per device if we want to achieve this, is this correct?
We could also define a new subnet which is used for internal management services such as SNMP, but if we consider that we might want to expand to using MR devices which can only hold a single IP address. Then we'd have to use different designs regarding management of these devices based on what the hardware is. So for example 1 subnet for cloud communications and another for the internal services on MS390 (or dual IP addresses) and then a single subnet for cloud communications and internal services for MR type devices. Would this be the correct assumption?
