We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hi team,
I want to ask:" Is the Meraki MS150 compatible with Cisco ISE?"
Is the Meraki MS150 compatible with Cisco ISE, and if so, which license does it require?
Thanks team.
Genereally speaking. any switch that supports RADIUS is compatible with ISE.
It depends on which features you intend to be using. Do you need Downloadable ACLs? Then there are certain limitations.
Yes, this is supported regardless of the model.
https://community.cisco.com/t5/security-knowledge-base/how-to-integrate-meraki-networks-with-ise/ta-...
