MS switch MR access point - RSTP setting
TinOmen
In a previous life I was running Meraki APs with Cisco switches and we set the AP ports on the switches to trunk and portfast.  I now have some MS switches and Meraki APs and I don't see the portfast option on the config.  Should I disable RSTP on the trunk ports connected to the Meraki APs for a similar config or would a more experience Meraki admin recommend leaving RSTP enabled on those ports?  The APs are MR44s with only a single port.
2 Replies 2
Keep It enabled.
