I have 2 pairs of MX with several ports connected in a pair of stacked switches and it has been working without any problem.
LACP & Link Aggregation
The MX does not run LACP or any link aggregation protocols. Connecting aggregated ports to the LAN of the MX is not supported; all connected ports should be un-aggregated. If multiple ports are connected to the MX from a single switch for redundancy, it is highly recommended that you run STP on that switch, to ensure that one of the redundant ports is safely put into a blocking state.
![alemabrahao_0-1668086113789.png alemabrahao_0-1668086113789.png](https://community.meraki.com/t5/image/serverpage/image-id/26691i4FF515E2FDA29208/image-size/medium?v=v2&px=400)
