[MS Switch] CDP/LLDP how working
Th1b0plz
I'm not find information accurate about protocol CDP / LLDP, how working this on meraki switch
- what is the actualisation time after a
new connection ?
- And the hold time for an old discover disappears on a port ?
- Possible to force actualisation manually ?
Thanks for information.
2 REPLIES 2
GIdenJoe
Re: [MS Switch] CDP/LLDP how working
I believe those are inner workings of the software on the switches themselves.  Not something we would know.
The only info I do know is:
LLDP frames are sent every 30 seconds with a ttl of 120 seconds
CDP frames are sent every 60 seconds with a ttl of 180 seconds
The switches should catch on quite quickly if a new entry comes up in the switch.  But they do seem to keep old entries on for a while and the change is not reflected on the dashboard immediately.
Th1b0plz
Thanks for your answer.
indeed the update during a new connection is quite fast
on the other hand the disappearance of an old connection seems to take several hours but how exactly
that is the question 🙂
