MS Stack Member Move
Zanda
Looking for a bit of guidance since I have not found any Meraki documents for this specific instance.  I am needing to move a stack member from one stack to a newly created stack.
In theory it would be,
  • powering down the single switch that is going to be the new stack
  • powering down the  existing switch stack
  • removing the stack member
  • plugging the stack member into the single switch
  • bringing everything up
  • going to switch stack overview and checking for detected stacks
  • provisioning this stack
Since there isn't an existing member that would be replaced, i would think there is no reason to clone the migrating stack member.  There is also no Layer 3 so the stack member is only operating at a layer 2 level.
So I guess I am really looking for any gotchas anyone may have experienced if any.
1 Reply 1
I would add an extra step or two after this one:
  • remove stack member in the Meraki Dashboard
  • factory reset removed stack member
