Long rang Switch
Islam-Hussien
Long rang Switch
Are the MS switches equipped with a long-range POE switch to support POE for 180 meters?
Islam Hussien
2 Replies 2
The maximum distance for Power over Ethernet (or any network data transmission) is 100 meters or 328 feet.
Brash
Extended range PoE is relatively specific to ruggedized type switches with 10Mbps connections.
Meraki doesn't have anything in this range.
