Hello, we have a small network, with two switch stacks, and are due to add a third stack (or just 1 switch), each cabinet is in different buildings, but the buildings are joined together.
I am asking what is the best resilient method to interconnect the switch stacks, I would have thought a triangle, but that would introduce a layer 2 loop?
I read someone's reply to another question regarding which switches to connect from/to, and if so can you aggregate across different switches in a stack?
Currently I have used 2 Fibre ports on ms225-1 connected to ms225-5, should I have gone 1-5 and 4-7 ?
and should I go 1-8 and 4-9? or is that a bad idea.?
It all works at the moment, but is there a better way?
Steve
![Cabinet routing.jpeg Cabinet routing.jpeg](https://community.meraki.com/t5/image/serverpage/image-id/22039i5CFBA97DCD4B4D67/image-size/large?v=v2&px=999)
