Linking an MS355 to Dell Force 10 MXL
We are looking to link a stack of MS355s to a pair of Dell Force 10 MXL switches in a blade chassis.
I know it is sold as a stacking cable but has anyone had any luck using the MA-CBL-40G-3M as an uplink cable?
With the Force 10 switches pretty much anything works, but we have some HP 10GbE switches where passive twinax cables just don't connect despite being recognised...
1 Reply 1
Support have advised that as the stacking cable is simply a standard twinax cable then it should work for normal data port connections (on a Meraki switch) so we're going to try a 1M one that we can temporarily remove from a stack...
