Limit Client Bandwidth Usage
HThiam
 Hi All ,
I have a wired client connected to an MS225 switch that is consuming a significant amount of bandwidth, as indicated in the Summary Report. The traffic is categorized as "Non-web TCP."
Since I’m not using an MX appliance, is there a way to restrict this client’s bandwidth usage  on the switch may be ?
Looking forward to your guidance.
RaphaelL
Hi ,
Won't be possible to apply restriction from the switch.
Those restrictions are only applied to a client connected to a MX or MR.
RaphaelL
Hi ,
As mentioned by Raphael, this is not possible on the Meraki Switch. Do you have a firewall on your network? You can create a QoS rule on your firewall.
HThiam
Got it . We have a Fortigate firewall indeed , will see how I can apply Qos to it .  Thank you both
