LAN to LAN MS250
LAN to LAN MS250
I have an L2 MS250 switch, this equipment will be directly connected to a Cisco Router.
VLAN 15 traffic and LAN to LAN
VLAN 110 server VLAN 130 user
Note: LAN to LAN does not have internet access.
How can I configure LAN to LAN on the switch ???
I will not have problems if I have LAN to LAN in one port and in another Internet service ???
6 REPLIES 6
Kind of a big deal ww
Re: LAN to LAN MS250
lan to lan, what is this? what are you trying to build?
you just want a l2 vlan on the switch?  then you only need to add that vlan on the ports of your switch
sorry is L3 my SM250
in my MS the VLANs are configured, then if a user wants to consult a service that is in the LAN to LAN this must be directed by the VLAN 15
How can I do that route?
if you need to route to a unknow subnet for your switch? make a static route to the ip of the router that you connect on vlan 15? .  subnet/xx  <upstream router ip in vlan 15>
or a default route to the  <upstream router ip in vlan 15>
That's right, the route you mentioned and I have defined it as a transit VLAN
that communicates the Meraki with the Router
I'm looking for "Initialize layer 3" under the Status section but I do not find out what the route is ???
