LACP between a Cisco enterprise switch and Meraki MS switch
dbauman
Greetings,
Any documents out there on configuration for LACP between a Cisco enterprise switch and Meraki MS?  More importantly, the Cisco side.  I know how to do Cisco  to Cisco and Meraki to Meraki, but cannot seem to get Cisco to Meraki to work properly.
GIdenJoe
The Meraki switches run LACP mode active with slow timers.
So normally if you configure mode active or mode passive on your Catalysts and don't change the timers you should have a succesful connection.
If you are doing MEC (etherchannel on 2 stacked Meraki switches) make sure their stacking config is working.
Else you will get two different actor ID's and the bundle will fail.
