LACP and 802.1X
RaphaelL
LACP and 802.1X
Hi ,
I have never tried this setup.
Is it possible to have a device ( let's say a phone ) , connected to port X and port Y in the same switch/stack and have an Access Policy on these ports ?
End goal is to have redundancy on a IP phone , lose one of the 2 connections and avoid the phone to re-do the full 802.1X auth on the other port and not losing the call.
I couldn't find anything in the MS doc that says that 802.1X and LACP are not compatible , but I'm unsure...
VivekT
802.1X and LACP are not natively compatible because LACP aggregates physical ports into a single logical link.
If you require redundancy for an IP phone while avoiding call drops,
consider:
Using MAC Authentication Bypass (MAB) on the redundant port.
Leveraging phones with built-in redundancy to switch internally between active links.
Exploring non-802.1X security measures like VLAN ACLs or port security.
Ultimately, achieving both 802.1X enforcement and seamless redundancy without call disruption may require trade-offs, as strict 802.1X is not designed for multi-port redundancy scenarios.
I have never tried it either, but I doubt it would work.
Would using a WiFi enabled device be an option?  Then it can failover between different APs on different switches.
RaphaelL
Sadly no , the only option is wired. Those are "specials" IP phones for traders.
Now I know we are talking about a higher acceptable price bracket ...
I have seen these passive Ethernet fail-over devices.  They have an Ethernet in, and two Ethernet's out.  The phone would plug into the "in".  The out's plug into separate switches.  As long as the device gets a link from out1, it uses that otherwise it passively fails over to out2.
I have never used such gear myself, but a quick Google found this option:
1+1 Ethernet Failover / Ethernet AB Fallback Equipment | Valiant
Personally if it was me, I think I would be tempted to look at something like a Cisco Catalyst C9404R.
Cisco Catalyst 9400 Series Switch Data Sheet - Cisco
It has dual supervisors, dual everything.  If you have a supervisor fail, the port automatically fails over to the standby supervisor.  It supports doing hitless upgrades.
