L3 Vlan SVIs on Meraki
navysubvet
On Cat switches, you could config a Vlan SVI with no IP address. How does one config/duplicate this in the Meraki environment? I have several vlans that were not migrated to Meraki, but those devices till need to communicate
It will be included when you set it for all.
You don't need to create a VLAN on Meraki switches.
5 Replies 5
It's not possible on Meraki switches.
navysubvet
My Meraki devices can ping google/outside, but can't ping my internal servers (like AD). How do I remedy that?
SnackSteeler
When you trunk up to your L3 device whatever vlans that are allowed on the trunk will be available. If your MS is L3 then you need IP's on your svi's.
navysubvet
All vlan SVIs reside on the MX. I do have those included across the trunk uplinks. I just wonder where I allow "all", if only the vlans with SVIs (and IP addresses) will show,. Must those vlans without SVIs be defined by number, or will they be included in the "all"? Hope that makes sense...
