We seem to be having intermittent internet connectivity issues. We recently added 43 Meraki APs to our Meraki network infrastructure. I'm afraid there might be some configuration issue somewhere.
Pertinent Information: -A large number of ports are showing STP issues. -All of the traffic is using one 1GB internet circuit. this includes the LAN and both staff and guest SSIDs -RSTP is enabled on all ports -The 1GB internet connection connects to our DMX switch which then connects to our Checkpoint Firewall -The issues seem to ramp up when we have a large number of visitors
What's been attempted so far -Added Loop guard to the affected front line switch (1071 Admissions) to no avail -Removed RSTP from the affected ports on said switch (1071 Admissions) -Limited the available bandwidth on the Guest SSID to 10% of all available bandwidth
Where else should I be looking? What do you advise?
How are your ports set up on your (I'm assuming) Meraki switches that connect to one of the AP's? Are they trunk or access, and have you got a native VLAN set up if it is a trunk?
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b6b3309de4ee1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b6b3309de4ee1_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b6b3309de4ee1_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b6b3309de4ee1_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6b6b3301ebd1e6","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
