- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Interface type on model C9300-48UXMM
Could anyone tell me the interface type (RJ45, SFP+) for switch model C9300-48UXMM. All the datasheet says is C9300-48UXMM 36 x 100M/1G/2.5G + 12 x 100M/1G/2.5G/5G/10G. It does not say the Interface type.
Thank you
Solved! Go to solution.
- Labels:
Interfaces
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
They are all RJ45 ports, SFP+ ports only do 100/1G/10G You can add SFP ports at the end in the optional module bay.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is there no model C9300-M that has 24 or 48 ports of SFP interface? Similar to MS425 but supports adaptive policy. As I understand it that MS425 does NOT support adaptive policy.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
There are at least four models, the datasheet here has them all: Cisco Catalyst 9300 Series Switches Data Sheet - Cisco
C9300-24S, C9300-48S, C9300X-12Y and C9300X-24Y
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As far as I am aware all 9300 switches can run in Meraki mode, but I am happy to be corrected if that is not the case?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The models shown above were added from firmware 16.4:
For the C9300X-12Y, C9300X-24Y, C9300-24S and C9300-48S switches, the Dashboard network's firmware version should be CS 16.4 or newer.
