Has anyone noticed the uptime time stamp is not resetting after a firmware update?
After MS 17.2.2 Update -
Event logs show firmware update device boot -
Cheers
Adam
Solved! Go to solution.
My guess would be dashboard side. But that's merely a guess.
Support (via a case) should be the official answer-er 😉
Known issue/open issue. You can open a Support case and they can link your issue to it so you get an update once resolved.
Is there any mention in that issue whether the defect is dashboard-side or device-side? As in, will it take another firmware upgrade to resolve this defect or is it just reporting wrong on the dashboard side?
