Hello all,
I wanted to ask some questions regarding the IGMP snooping and querier functions in Meraki MS switches. We only really use the MS120 / MS125 series as we do small networks to support out AV installations , we are an AV not an IT company.
A lot of our projects just use one switch but we have more and more coming up with 2 x MS125s and we aren't providing our own router, instead we will uplink to a trunk on their (IT company's) core Fortinet switch.
My questions are:
1) IGMP is enabled by default on meraki switches but not querier, do I need to setup an interface on one of the switches in a system to become the querier for the whole network? I'm unclear on how this works and how the switches / client devices know who is the querier.
2) Do you need an MX for IGMP querying to work, or is it handled entirely within the MS switches?
3) One of the network audio protocols we are using is called Q-LAN which is based on AES67. Supposedly, this protocol doesn't like jumbo frames / large MTUs, but we need it for the video encoders / decoders. And the manufacturers documentation says to disable jumbo frames on any switch ports that have Q-LAN devices attached. In meraki the MTU size is set on a per switch basis meaning I can't disable large MTUs on these ports only. Theoretically, if all Q-LAN devices are on their own dedicated VLAN and only communicate to each other, would it mean they'd never receive a large MTU despite the MTU size of the switch being set high?
Thank you in advance,
