On your MS210, configure Company ports as Access on a VLAN that is not currently in use on your Home MX, e.g. VLAN 999.
On the uplink port from the MS210 to the Home MX, prune VLAN 999 (Allow all, except 999).
On the Home MX, configure only relevant VLANs to be allowed on the trunk.
Ensure, that the Company has configure the Company MX LAN ports as access ports.
Connect one of the Company MX LAN ports to one of the Company Switch ports on the MS210.
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
