How to talk to a specific switch via switch.meraki.com if using multiple switches?
from_afar
I understand that you can get to config pages via switch.meraki.com, but I'm not clear how it works if you have multiple switches. Is there a way to talk to a specific switch via switch.meraki.com or is the only option to plug directly into the management port?
You can get it via IP.
2 Replies 2
franknotmike
Just make sure you have
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
Enable that if that is going to be done. Probably not recommended for the MX WAN though.
