We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
How to clear or release the learned sticky MAC address from the Meraki switch port for new connection.
Solved! Go to solution.
You have to delete them manually under the port config or perhaps with an API endpoint https://developer.cisco.com/meraki/api-latest/#!update-device-switch-port
Thanks!
