How to check devices (MR,MS ,MX ) reachability with meraki cloud
Merakisupport12
2 Replies 2
RWelch
Using the Ping Live Tool
Brash
As stated above, if you're looking to run a reachability test from a device already connected to the Meraki Portal, you can use the Ping Live tool to test ping connectivity.
If you're investigating why devices are not connecting to the Meraki dashboard, you would access the device locally via the local admin page to check the status.
