How do I know if my Switch is registered?
Ghisl1
Hello, I just bought a used Meraki Switch and I would like to know if it is already registered on the cloud? how can I find out quickly? if it is already registered to I there is a way to release it? THANKS
1 Reply 1
If you try to add it to your inventory and the device is in another organization's inventory you will receive a message informing you that the device has already been registered.
However, only those who sold it to you can remove it from the organization's inventory, Meraki support cannot help with this.
So my suggestion is to contact whoever sold it to you.
