Fluke LinkRunner - shows switch MAC
Capt_Caaaveman
I have MS390 switches CS 15.21.1, when we go to fluke a port, the switch info is just the MAC.  how can we get it so show switch name
13 Replies 13
I believe this is unrelated to Meraki. Have you tried contacting Fluke?
Capt_Caaaveman
We
are in the process of that.  just want to see if others had the issue and if there is a fix.
You obtain this information via LLDP, so I don't know if you need to perform any additional configuration on Fluke.
I'd upgrade to CS 16.8 as 16.3 included a number of CDP and LLDP fixes.
Capt_Caaaveman
That works!  But stacked switches do not show the switch name.
Do they show a stack name, IOS-XE considers a stack one switch
Capt_Caaaveman
they show MAC info still
I'd log a ticket with support.  If 16.8 fixed it for single switches they must have some idea what needs changing for stacks.
Are you using any port security features?  802.1x?  MAC restrictions, etc?
Capt_Caaaveman
nope
Are you running recent firmware on your Fluke?
Capt_Caaaveman
thats next.  we have a couple different models.  having the team gather that.  but the CS 16.8 update fixes the name for individual switches
Ryan_Miles
Do your switches show this on the switch detail pages "Current version: Not running configured version"? If yes, I would recommend opening a Support case.
