Do Meraki Switch SFP Ports have a higher buffer than the Copper Ports?
RH6379
We're debating whether to purchase SFP modules for our Meraki MS120-24's and use those as uplinks or just use one of the copper ports.  My boss mentioned that the SFP ports might have a larger buffer.  Does anyone know if that's true?  Also, is there any documentation that talks about that and how/if the ports are split up into ASICs?
1 Reply 1
RVilhelmsen
the cobber interfaces is Marvell Alaska V 88E1680 chips and the fiber is Marvell 98DX3233A1. Maybe marvell has some spec. pdf.
The SoC in a Microsemi SmartFusion2 - https://www.microsemi.com/product-directory/soc-fpgas/1692-smartfusion2
Memory is SK hynix - https://www.skhynix.com/products.view.do?vseq=913&cseq=74
and Nand flash from Spansion.
It´s all the same hardware in the 120 series and nothing home grown. All bougt from other venders.
https://www.rovi.dk/meraki-ms120-8-switch/
