Disable DTP / Unknow protoclols
Brandon0712
Hello Community Meraki.
I want a consulting.
While in observation one interface in Catalyst to MR56 ,I realized that it has "unknown protocols". I clear the counters. I thought it might be DTP, but i verify te interface and are "no switchport nonegotiate".
I clear counters, the "hellow" mesage it recived at 30 seconds, i think that MR55 send DTP.
Do you know something similar?
Thanks for the support.
To disable DTP you can run this command on the switch port:  switchport nonegotiate
Solved: switchport no negoiate command - Cisco Community
Brandon0712
Thanks for the clarification.
I already applied the command but I still receive unknow protocols 😕
Try doing a packet capture and see what shows up.
Brandon0712
Good idea, I'll try it.
thank you
