May 11 2023
9:57 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
May 11 2023
9:57 PM
Difference between FP and LP
what is the difference between the P, LP, FP of Poe switches is only the power or only half of the ports work as PoE ?
Solved! Go to solution.
May 12 2023
7:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May 12 2023
7:06 AM
Exactly as Brash stated. The PoE budget values are all listed in this doc. https://meraki.cisco.com/product-collateral/ms-family-datasheet/?file
2 Replies 2
May 11 2023
10:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May 11 2023
10:03 PM
The difference is the total amount of available PoE power. You can verify the PoE power differences in the spec sheet
May 12 2023
7:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May 12 2023
7:06 AM
