I am having an issue and I want to know the solution. Maybe updating to IOS-XE version 17.9.8 will solve the problem?
C9200L_48 [2] C9200L-48T-
Monitor Only
Device is running an unsupported firmware version.
Current version: IOS XE 17.12.6"
Solved! Go to solution.
Yes, the switch will reboot during the upgrade process.
I would upgrade to at least 17.15.4 this is a supported version.
The minimum supported IOS-XE version for Meraki Cloud Management with Device Configuration (previously known as monitor mode) is 17.15.3
Enable Cloud Management for Catalyst Switches with Device Configuration - Cisco Meraki Documentation
One more question. I’m not sure whether the switcher will reload if I perform the upgrade.
