Compatibility For Sfp and Stacking
Shamshad
Kindly let me know can we populate the MA-SFP-1GB-SX in MS250 uplink port (10G).
and also let me know will this cable suitable for stacking purpose in MS250 MA-CBL-40G-3M
How many stacking cable is required for the stacking purpose in MS250 and do we need to buy SFP module as well for stacking purpose.
2 Replies 2
AjitKumar
Hi Shamshad
Hope you have referred the following Datasheet.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
I do not see any compatibility challenges for the following accessories with MS 250
MA-SFP-1GB-SX
MA-CBL-40G-3M
You do not need to buy SFP modules for stacking.
Number of stacking cables shall be equal to the number of switches you are planning to put in a stack.
You may also refer to following url
https://documentation.meraki.com/MS/Stacking/Switch_Stacks
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Shamshad
Thanks Ajit.
It helps
