Cloud Monitoring - PoE consumption
xaviervalette
Hello Meraki community 🙂,
I have a dashboard with 79 Catalyst in cloud monitoring,
I wanted to know if we were able to monitor the PoE budget / consumption of those switches ?
Indeed we can launch Terminal and do :
SWITCH_CLOUD_MONITORED#show power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1           370.0        5.6       364.4
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/1   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/2   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/3   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/4   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/5   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/6   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/7   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/8   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/9   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/10  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/11  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/12  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/13  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/14  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/15  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/16  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/17  auto   on         5.6     Ieee PD             2     30.0
Gi1/0/18  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/19  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/20  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/21  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/22  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/23  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/24  auto   off        0.0     n/a                 n/a   30.0
Totals:          1    on    5.6
But I was searching for a more programatic solution to gather and monitor the 79 switches PoE budget / consumption,
Any thoughts on this point ?
Thanks a lot team !
Xavier VALETTE
7 Replies 7
It is on the "Power" tab for the switch.
Programmatically, I would take a look at this API:
https://developer.cisco.com/meraki/api-v1/get-organization-summary-switch-power-history/
xaviervalette
Hey Philip,
Thanks for your feedback,
My concern is on Cloud Monitored Catalyst switches :
I can't find the Power tab for those devices
Xavier VALETTE
The screenshot I supplied was from a cloud-monitored C9300 ... This particular one was running IOS XE 17.9.4.
xaviervalette
And the screenshot I am providing is from Cloud Monitored C9300 in IOS XE 17.9.4a (not Cloud Managed),
So what I am getting from this, is that the Power tab is not available for Cloud Monitored switches, but only for Cloud Managed
Xavier VALETTE
My mistake.  I meant to say cloud-monitored, not cloud-managed.  My screen shot was from a cloud-monitored C9300.
xaviervalette
Thanks for the feedback Philip 🙂,
So on your side, for a Cloud Monitored switch, you are able to see :
- Summary tab
- Ports tab
- Power tab
- L3 routing tab
- Event log tab
- Location tab
- Tools tab
And on my side I am able to see:
- Summary tab
- Ports tab
- Location tab
- Tools tab
- Config history tab
How can we explain this difference ? On MS switches I have the same view as yours, but for Cloud Monitored switches I don't, no matter the organisation (Meraki demo org, my customer orgs, ...)
Xavier VALETTE
jimmyt234
Not that it helps much, but for the 1 customer who currently has cloud monitored C9200 and C9300 switches we only see the list of tabs you get (ie. I don't see a Power tab either).
