Cisco Catalyst Meraki C9300X-24HX-M Gigabit Switch stacking will criss croos or a to a & b to b
amit21
Cisco Catalyst Meraki C9300X-24HX-M Gigabit Switch stacking will Criss cross or a to a & b to b
2 Replies 2
rhbirkelund
Cross them. A to B, or B to A, both are fine. But they should be crossed, as also described in the Stacking document https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Physical_Switch_Stack_Configuration_Steps
Ryan_Miles
Meraki Employee All-Star
Crossed is preferable for future expansion. In a two switch stack it doesn't really matter. But, if you ever add a third switch it requires slightly less cable moves if the starting point is a crossed arrangement.
You can visualize what I mean with these animated slides.
