Can I use 2 x C9300L-STACK-KIT to stack 2 x C9300L-24P-4X-M under Meraki Cloud Manage mode?
FB1984
I ordered C9300L-STAK-KIT2-M, but it will took CISCO 42 days to deliver the kit. Try to find interim of using C9300L-STACK-KIT, Can Meraki expert confirm two part number are indeed the same, so I can use in-stock C9300L-STACK-KIT
RWelch
C9300L stack kits - Cisco versus Meraki - Stacking (maybe it will help you).
RWelch
FB1984
yes, I found the original post after I submit the question. Save me lots of efforts. Thanks
They are not the same or compatible.
